Displays RSVP-TE information about MPLS interfaces.
| vlan | Display information for one VLAN. |
| vlan_name | Specifies the name of the VLAN. |
| detail | Display RSVP-TE information including the interface up time and LDP control packet counts. |
| counters | Display only the RSVP-TE control protocol packet counts. |
N/A.
When the optional counters keyword is specified, only the RSVP-TE control protocol packet counts are shown.
The following command displays detailed RSVP-TE information for the interfaces associated with VLAN 1:
# show mpls rsvp-te interface vlan1 det VLAN Name : vlan1 Local IP Address : 11.121.96.20 MPLS Admin Status : Enabled MPLS Oper Status : Enabled RSVP-TE Admin Status : Enabled RSVP-TE Oper Status : Enabled RSVP-TE Up-Time : 0d:1h:19m:46s # Neighbors : 1 Receive CIR : 50000 Kbps Transmit CIR : 50000 Kbps TE Metric : Use IGP Cost/Metric Hello Interval : 3 seconds Refresh Time : 30 seconds Hello Keep Multiplier : 3 Refresh Keep Multiplier : 3 Summary Refresh : Disabled Summary Refresh Time : 3000 milliseconds Bundle Message : Disabled Bundle Message Time : 1000 milliseconds ---------------------------------------------------------- Dir Pool CIR Available (per priority level) 0 1 2 3 4 5 6 7 ---------------------------------------------------------- Rx 50 50 50 50 50 50 50 50 50 Tx 50 50 50 50 50 50 50 50 40 (Rx)Receive Bandwidth (Tx)Transmit Bandwidth Message Sent Received ---------------- ---------- ---------- PATH 165 165 PATH_TEAR 2 3 PATH_ERR 4 18 RESV 160 145 RESV_TEAR 0 2 RESV_ERR 0 0 RESV_CONFIRM 4 1 SUMMARY_REFRESH 0 0 BUNDLE 0 0 HELLO 42 30
This command was first available in ExtremeXOS 11.6.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
